Looking for some help tracking down a fairly significant fuel leak coming out the main exhaust port while running AND not. 8’x8’ solid sheen on water after 5 mins stopped. Not gear oil, def fuel/oil mix. Rebuilt carbs recently that didn’t seem to help much. Compression is low, but all within 10%. Fires right up cold. See no visible fuel line leaks/issues under cowl. A little slow out of the hole, but happy with about 45mph top speed on plane. Sometimes does stall at idle and in gear on the water, but runs like a top on the muffs? Can’t in good conscience put this boat in the water with a leak. Any ideas would be appreciated.
Vro pulled by previous owner. Would a bad pump diaphragm cause the excess fuel out? Bad reeds?
Thanks!
j150stlcem 150 Cross Flow pushing a 18’ bumblebee
Thanks!
