dlogvine
Master Chief Petty Officer
- May 4, 2015
- 839
I started putting together 1993 4.3 V6 Mercruiser. It has no balanced shaft, standard rotation. First thing, I put the freeze plugs. 1.5" brass plugs locations (8 total) were easy identifiable, camshaft plug also (which I would install later after the camshaft bearing inserted. But then I had 4 more freeze plugs left. Two threaded ones seems to be the drain plugs and I might just use the better easier removable ones, but the other two were non threaded plugs and the only holes I found close in size were two holes around the crankshaft seal location. However, these holes were threaded and Im not sure if these are the right ones. Looked at the engine manual, not even a slightest hint of their locations. So the question is, where do they go and if the other two small drain looking plugs went into the correct places? Images are attached. Thank you
