1993 19ft nitro with johnson 200 GT Venom. This engine currently has a raker 24 pitch prop. Does anyone here have any suggestions????? I am above wot rpm range in the high 6000 range so I just back of of and keep around 5000. Do I need to go to a 27 pitch????? Had Hijacker pro installed and it is set at 1/2" above its bottom end on the adjustment. Before the plate was installed I was hitting 66 to 68 by gps and now after the plate was installed I have lost on the top end and turning more rpm.
Need some advice!!!!!!!!!!!
