100hp overheating
tacodads
71 100 hp evinrude is overheating on the muffs. I pulled out the thermastat guts. can I run while I wait for the parts?
Thanks,
Taco
SparkieBoat
Re: 100hp overheating
so long as the water is flowing and it is not overheating..it should not hurt it to run without thermostat..may not run quite as well but I think it is fine.
Sparkie
tashasdaddy
can I run while I wait for the parts? yes, but get the parts ordered. it will run cold, and build up carbon. i would do a decarb after the new stats. are you sure the impeller is OK?
tacodads
Impellor is working. I hooked a garden hose up to the water inlet on the cylinders, water was able to flow out. My thought was are the water jackets clogged? The water flowed out. I'm assuming this means they're clear? Ihave ordered the vernatherm and a new impellor any way.
Thanks,
Taco
