Re: Emergency Starting if Rope Broken
My 1962 Merc 110 has a similar flywheel. I couldn't do mine by spinning it with my hands. I have successfully done what you are talking about three ways:
1. Carefully remove the top cowl after starting--just be careful.
2. Wrap a rope around the flywheel, crossing the first turn over the end of the rope to hold it. Wrap it tight. Friction works. May need to try a couple different ropes to find one that works. Or try a strap. If the flywheel is too slick, maybe a turn of tape on the wheel will give better purchase.
3. The power drill with a socket (as described above) works also, and is good with a really hard to start motor since you can crank the daylights out of it. Had to do that on one with a bad choke butterfly before I figured out that was the problem.
With all three, be careful. My attorney asked me to add this advice: I must recommend you not do any of these for safety reasons. In fact, don't use outboard motors and never go out on the water. In fact, never go outside. There, I think I coverd all the bases.
Motor Boater Bill
