Quicksilver 3000 classic throttle control
bill chambers
Took the throttle body apart to replace the neutral safety micro switch and in doing so a small apprx 1/4 inch pin fell out and i did not see where it came from. A schematic/diagram of the inner parts and a parts list would be helpful. Or a description of where it goes.
Fun Times
Odd, not seeing a modular on the quick for the 3000 but am able to locate both older 2000 and newer 4000 parts breakdown.
Number 9 or 10 maybe for examples,
The following would offer a 3000 opened up photo… maybe you can see the part in question,
Bt Doctur
let me get the manual but the only pin that size was used to activate the shift lever lock .was operated by thre top lever in the handel
