Trying to identify 2000 Johnson/Suzuki 50 HP (J50PLSIB)
garrettbirkhoff
Hey all, I am tearing my hair out trying to get parts and a manual for the outboard we have. It is a Johnson 50 HP four-stroke, supposedly made September 2000. The model number on the plate is J50PLSIB -- but I see this referred to occasionally as a 2-stroke, but it takes straight gas and has an external oil tank, and I also think the motor may have been made by Suzuki. I'm trying to find a new rectifier for it, but all the ones for related boats (Johnson or Suzuki) are different (they are hexagonal; this is rectangular--photo attachedJ50 Rectifier side.jpg). It might have been made for either the US or Canadian market originally. Not being able to find an authoritative parts listing is driving me crazy. Any ideas?
Mc Tool
Dude ... Thats definitely a 2 stroke motor . The external tank should be filled with 2 stroke oil and it is then drawn into the motor by a pump and metered and then the correct amount of that oil is mixed with the fuel automatically......so yes you would put straight gas in the tank .
As for the reg/rect ....doesnt matter what shape it is as long as its able to handle the current .
Just an example .....as long as it physically fits ( yes it says 4 stroke but it doesnt make a difference .....they are like spark plugs in that they use the same one for lots of motors ) and ,yes it Chinese but the one you buy from Johnson for 3 times the price will be too ( Johnson dont make reg/rects ....the buy them in ). Have a look on ebay ,Aliexpress , Amazon ....there are heaps .🙂
Here is the Aliexpress reg/rect I fitted to my Tohatsu , cost me NZ$18 . I had to make a long bolt with a couple of extra washers to fit it , ....bonus ...the hour meter slips nicely over the fin so I didnt have to make a bracket for that.
garrettbirkhoff
Thanks so much for this! I just inherited this boat with no manuals or anything. I actually didn't know they did separate oil back then. Are there any sources where I could learn about how to test the charging system on this one?
Mc Tool
Put your volt meter on the battery , motor off it should show about 12v , then start the motor and hold it at a fast idle and you should see that voltage at about 13.5 to 14v . If there is no rise give it a quick rev and it should go up . This shows the charging system is working . If there is no rise its not .......we go from there 🙂
When you run the motor you must have water going to it , either with the ear muffs or the motor in a tub of water , or actually in the lake river whatev
garrettbirkhoff
I don't see any rise, or any change as the motor shifts from idle to ~2500 RPMs. So now could the problem be in the rectifier, or in the stator? Help videos I see online for testing rectifiers look very different from my set up.
Crosbyman
check yellows for AC volts from stator if ok .....bad rectifier or connection back to the battery B+ check all wires for corrosion
check B+ on RED out of rectifier to see it rises !! as it should like the battery test above
reconfirm engine mdl# !!!
The---SI---makes it a 2001 model.-----Color is correct for that year I think.
garrettbirkhoff
Got it! Thanks. The rectifier was faulty. Good voltage coming from the stator, but current flowing both ways across one of the diodes in the rectifier. I'll see if I can swap it out. And that it is a 2001 model, despite being made in 2000, helps clarify.
