1992 OMC 3.0 Cracked Block
Jcgonzal
New member here, just bought my first boat. I knew it was going to be a project, but didn’t anticipate this. Long story short the previous owner left the boat docked overnight and somehow took on water; he took off the fuel pump and water separator looking for water in the fuel system but didn’t find any. He then moved and lost those two parts.
Fast forward about two years of sitting and I buy the boat. I put a brand new fuel pump and water separator on, also get the carb professionally rebuilt because it was beyond crusty. I get the boat started on the hose for the first time and immediately get water leaking out of the manifold side of the engine…was hoping it was just a cracked manifold. Took the manifold off tonight and found a sizable crack in the block directly below the exhaust ports. I also checked the oil and it was a milkshake, looked clean before I ran it. I’m very green when it comes to boat motors, so I guess my question is: what are my options? Would this crack allow water into the oil, or would that have to be manifold/head gasket related? I’m more than deflated, was really hoping to get the family out on the water this summer….I appreciate any and all insight.
first, welcome aboard
that block went thru a freeze. the block is busted on the outside where you see it, and on the inside, just above the pan rail
the rusty goo in the upper right of the corner says your manifold was also freeze busted.
you need a new motor.
since it sat with water in the oil, none of it is salvageable except hardware.
any 1991 to 2015 3.0 will bolt right in. for the base motor you can get a used one from any source as they all came from GM
a reman'd motor from michigan motorz will be $4100, a new one is about $5700
you will need OMC specific manifold.
you can unbolt all the OMC stuff and bolt in a complete 1992 or later Mercruiser 3.0 and Alpha drive should you go looking for a complete bobtail.
what is the condition of the transom and stringers in your 36 year old boat?
Jcgonzal
Awesome information, thank you! The transom, floor and seats seem to be in great shape, which is the only reason I’m considering replacing the engine. I only have about $1200 invested so far; obviously new or reman would far exceed the value, so I’m hoping to find used.
Ayuh,...... Welcome Aboard,...... Are you going to do it, or hire it out,..??
Jcgonzal
I’m relatively mechanically inclined…never done a motor swap (other than one motorcycle) so I’m hoping to do it myself, if I can find a good deal on a motor!
Jcgonzal
So just so I’m clear, are the OMC and Mercruiser 3.0 block and head the same? If I was to find a Mercruiser engine, would I just have to swap accessories/manifold/etc?
Ayuh,..... As Scott said, the long blocks '91, 'n up are all the same,....
Big Gee
The least expensive route may be to find a cheap donor boat with a usable motor. Just be sure to inspect it thoroghly before buying it.
And forklift motors and trash pump motors.
The 3.0 liter starting in 1991 is a built in Mexico industrial motor sold by GM for a bunch of applications
The motors were sold to Mercruiser, OMC, Volvo Penta, etc. The motors were the long block, water pump, flywheel and starter with the ignition being added later.
The marinizers then added the ignition system, the front accessories, their own manifold and carb
So yes, you would have to swap your accessories and source a new manifold
Jcgonzal
That’s kind of where I’m at. Been searching Marketplace; assuming I can find a deal at the end of the season with people not wanting to store their boats for the winter.
Jcgonzal
So i did find this ‘94 engine, don’t know how many of you have Facebook to be able to look at the listing. The ad says it “runs great”, but it sure doesn’t look like it’s running very smooth in the video. Do you think it’s worth bringing some muffs with me, running it on the hose, and just giving it a once over? I’d check the oil for water as well, obviously.
Big Gee
It doesn't look like it's running very smooth in the video, but for $400 if it's not too far away, why not?
From the pictures, he's already pulled it from the boat. Buying just the engine beats buying a donor boat, pulling the engine and then having to dispose of the hull.
Scott06
yes also the volvo penta 3.0 is the same GM long block. Best bet find a beat up boat and jank the driveline out
Scott06
yeah runs great is a joke.. 3.0s are no the smoothest idling engine but if it has good compression and makes decent oil pressure on a test stand likely needs a tune up and carb rebuild
Lou C
I'd pass that rumbling noise sounds like bad bearings.
Don't waste your time
Jcgonzal
Found a donor! ‘93 Bayliner Classic. It’s all Mercruiser, so will be buying a new exhaust manifold and using my carb/accessories. Will try to recoop some of the cost by selling the Mercruiser manifold & carb, and the trailer is decent so I’ll sell that as well. Only paid $600 for the package, hoping for the best! Had to check the block right away, already looking 100 times better.
