DeepCMark58A
- Aug 17, 2015
- 3,433
I will not argue with your result.
What does the pee stream mean?Did you not read the part about the temperature gauge ?
If the temp is proper and the pee stream is strong everything is good to go![]()
Cooling water indicatorWhat does the pee stream mean?
PEE stream means nothing. Only means that water got to that point. The only good pee streams are the ones plumbed in after the thermostat.Cooling water indicator
