1984 3.0 cobra
Jakem
Good day....working on friends boat wich had a cracked head...new head installed and tdc set however the rotor is aiming back towards number 4...am I missing something
alldodge
firing order is 1-3-4-2
It's pointing at 4 means it's 180* out, so move the plug wires in the cap 2 holes or pull dizzy and turn rotor so it points at 1
Jakem
Morning...has anyone got the part number for lifters for this engine
Lou C
I looked the OMC catalog on marineengine.com and oddly they list everything in the valve train except the hydraulic lifters, but Merc used the same engine so I looked it up in the Merc section and here's what they show:
Not sure if these are just standard Chevrolet small block flat tappet lifters, or unique to the 4 cyl models. Anyone know?
Jakem
No there not cupped my concern is if I put it all back together and theres a sticky one I'd have to pull it back apart
alldodge
The great part about the 3.0 is it has a inspection cover, so if there is a bad lifter it can be replaced without tearing the motor down
