Used or reman outboard
wvmedic
I need to replace a 1995 Evinrude 90hp that has a water jacket crack/brake somewhere putting water in the lower left/port looking at the motor from the back.
I am in WV and used or reman outboards are hard to find.
Any recommendations on a reliable source of used or remanufactured outboards reasonably close to WV?
I would prefer fresh water and Gen 2 Yamaha 115 hp 4 stroke.
I don't want to buy someone else's headache.
Thank you, Jeff
There are rebuilders of powerheads. iBoats has (or had) some sources. They ship a reman powerhead to you. You strip your block, transfer parts to the reman block, and ship your's back.
Of course that gives you the same engine.
wvmedic
That is probably my best option. I'm looking at Crowley now. They have a 100hp powerhead for the 90 degree crossflow lower to replace my 90hp crossflow.
Do you know if they are reliable?
Jeff
It is doubtful that Crowley remans the blocks. It is likely some local shop that they buy from.
I bought a Merc IL6 reman block from a rebuilder associated with iBoats.. It was fine, although it did not have the power of a new block. The price was right, I thought.
airshot
Depends on the rebuild....rebuilt to new factory specs, or rebuilt to acceptable running condition...
When I worked in Largo Florida (just north of Pinellas Park), had a few co-workers use this shop down the street from the office. It helped that you had to drive past the micro brewery to get there.
they do the rebuilds there in the shop.
https://outboardmarine.com/ I personally do not have experience, however the co-workers all said good things.
wvmedic
Thank you Scott, doesn't look like they have my powerhead available.
jimmbo
how would it not have the same power?
Some People, including some Mechanics, think every I6, or V4 Powerhead is Identical, despite there being a 50hp difference. After all, in their Eyes, it is just a difference in the Jets in the Carbs.
redneck joe
so in something that will not be a stretch, can you pretend i'm an idiot elaborate just a bit pls.
jimmbo
In the Late 70s through into the 80s there were 3 inline 6s, a 90, a 115, and a 140. Although all of them were the same Displacement, and shared a few Parts like the Crankshaft,, there were many differences, Porting and Port Timing was different, in some cases there were what was called Power Porting, which required a different Block and Pistons. The Number of Reeds could vary, Carb Size would change, as well as Exhaust Tuning.
In the early 80s, OMC also had 3 engines of the same Displacement, again they were 90, 115, and 140. Porting was different, as was exhaust tuning, Carbs were different sizes, and the Cylinder Heads varied in Combustion Chamber Volume.
These OMC Engines did offer the Option of, by changing some Parts, and some machine work, the 115 could be converted into a 140, and the 90 could be converted to either a 115 or a 140. That wasn't possible to do with the Mercs, oh they could be hopped up, but they wouldn't be like a Production Motor
On some of the OMC 9.9 and 15hp, it was simply a carb Carb Change, on others it was a Carb, and Exhaust Tuner. On the OMC 22in Motors, known as the 18/20hp also shared the same Displacement. On these the Blocks and the Porting were Identical, but in this Case, the Port Timing was changed by using a Piston where the Location if the Piston Pin was different. This also reduced the Compression Ratio, so a different Cylinder Head was used to regain it. Crankshaft was different, as in being much more accurately Balanced, as the 25 WOT Range was 1000 rpm higher than the 18/20. Putting a 25hp cylinder Head on a 18/20 would result in too much Compression, Detonation, and Engine Damage
No difference than an average 350 cubic inch small block Chevrolet. Between 85 and 600 HP by changing the mix of parts from the same displacement
