Replacing water pump impeller for first time
stevh1155
From what I've read, it seems pulling the LU off and replacing the impeller and all the gaskets is fairly easy, however sliding the lower unit back on can be a bit of a nightmare! I have the Mercury service manual for my motor (1978 1150 ELPT), and it states to First shift into forward gear, then tilt motor until stop lever can be engaged. Then shift engine to neutral gear and begin removing the nuts and bolts. I have no idea how heavy these are but I'm guessing around 35 lbs. or so? My plan is to use a ratchet strap for support while I put things back together and to use a marker on the shift shaft when it comes off so I can get it back in the exact position it was in. No one's going to be touching the shifter up at the helm, so that shouldn't move. I've read many threads ad nauseum about doing this and each uses a little different method, so I thought I would just try going by the book. I have a Quicksilver pump kit that looks like it has all the right parts. I just bought this boat last fall and have been putting this off too long...anyway, to all of you that have done this many times, does this all sound about right? Thanks!
Leave it in forward when you take the lower unit off.----Replace impeller.---Slide it back together.----Have an assistant rotate flywheel to engage driveshaft splines.----Easy project.
You will want to replace the impeller, ss wearplate and 2 gaskets as a minimum. Check water pump base for melting (looks like scratches). Replace if found. Check SS liner in upper waterpump. If scratched, replace upper water pump.
I take the gearcase off and install it in neutral. I find that much easier.
Make sure plastic shift rod fitting is in midsection. Be prepared to wiggle shift handle to mate it with gearcase.
Gearcase is 40-50#. If the motor is tilted up, it is manageable. Grease shift rod and driveshaft splines before reassembly.
Jeff J
The splines never line up for me if I leave it in neutral and when it is in neutral there is no way to line up the splines. I leave them in gear so I can align the splines by turning the prop shaft.
Tilting it up to use the motor latch is a safety thing that cannot be done on a lot of pontoon boats because the motor will not tilt that high.
Jeff, you could turn the flywheel to align the splines. A 1/2" socket on one of the outer flywheel bolts does the job. I usually use a lifting eye, with the handle of my ball peen hammer thru it as a lever.
You can also move the gearcase rotationally before installing the water tube. That will sometimes align it.
Jeff J
Yep, I know all of that. I can’t reach the flywheel while holding a lower unit and rotating the prop shaft is a lot easier and faster than rigging up something special. I mostly work on 150-250 hp four strokes and my F70. I have gotten to where I have to use a jack to get the 250 back together. That’s a lot of weight to be screwing around with when it won’t line up.
Jeff, I have always been able to reach the flywheel while holding the gearcase in place. Of course, my speedboat is a low boat, making that easy.
If I try to install the gearcase in forward gear, often the shift splines will not align properly and the engine will not shift into reverse or sometimes even neutral, and the shifter needs to be turned CCW in forward to align it properly.
It therefore makes sense for me to install the gearcase in neutral, as that is a positive detent, unlike both forward and reverse which have many degrees of turning freedom.
stevh1155
That's the way that the Mercury service manual says to do it, but what I didn't understand was why they tell you to start off in forward gear before you tilt the motor all the way up and then shift to neutral after the latch is locked.
stevh1155
Do trim models have a mechanical reverse lock mechanism, or is it handled with the power trim? I looked and I just don't see anything that would engage the tilt angle pin. I can raise or lower the motor in neutral or forward (I didn't try in reverse). The service manual describes how to check the reverse lock on models WITHOUT power trim but doesn't say anything on models with PT. I just tried to swing the motor back, and it doesn't budge in any gear, feels like something solid is preventing it...maybe hydraulic lock?
Jeff J
Must be an old Mercury thing. The gear selected has never had a bearing on anything I owned with power trim. My first one was a 35 or 40 hp Johnson in the early to mid nineties. Replaced it with a new Force. Then an Evinrude and now a Yamaha. They all tilted full up no matter where the shifter was. I work on bigger Mercs, Suzukis, Hondas and Yamahas. I don’t think any of them are restricted as to when they can be tilted full up.
My 2-stroke experience is pretty limited but I have never had a problem with the shifter moving when replacing an impeller. I wipe it off and put fresh grease on it but I don’t turn it. I replaced a prop shaft in a 175hp Suzuki once. I think that is the only time I ever had to monkey with the shift shaft to reinstall the lower unit.
stevh1155
After I investigated a little further, I see a label on the power trim pump that says to enable reverse lock to turn it one way, and to disable turn it the other way. So, aha, that is how it works! I would assume there's some built-in safety mechanism to allow the motor to swing up if you hit an object in the water? (I hope!)
jlh3rd
I've done 2 merc. impellers in the last 5 years. One on a 2005 60 hp Big Foot . The other on a 2021 115hp CT, month ago.
I did the 60hp with leaving the shift in forward, as that's what I had read/heard (not mercury). I had to move the prop a little to get the alignment. Not hard, and the 60 hp gear case I could handle.
The 115, I did what mercury said, left it in neutral. I used the ratchet strap method also. So the shift shaft would move, not stay exactly in position when re-installing the lower unit. I ended up having to use mini vise grips lightly clamped on the shift shaft and were thin enough to fit in the work space which allowed me to use one hand to tweak the shift shaft and the other hand to work the case up, thank god for the ratchet strap. I also left the prop off as dealing with the heavier case, I felt made it easier to handle....It was.
All in all, wasn't bad. I'll leave it in forward next time.
Do you have a stand to set the lower unit in. Makes a difference also. Double check the impeller direction.
stevh1155
My prop is aluminum, it probably wouldn't make that much of a difference in weight. I don't have a stand, but I do have a couple of 6" thick blocks of wood and was just going to sandwich the skeg in between and clamp it with a bar clamp. They're wide enough to keep the whole thing from falling over.
airshot
Be sure to coat the impeller and housing with some silicone grease before assembly, makes turning the impeller much easier and adds some lube on initial start.
On the non PT Mercs, the motor needs to be in forward to tilt it. Power trim Mercs did not have the mechanical lock down rod, of the non PT motors.
Jeff J
Thanks, good info for those of us who haven’t seen one.
I forgot 2 of the motors I owned about 20 years ago. Both were 2-stroke. One was a Johnson V-4 on a Stratus bass boat and the other was a Mariner 90 on a pontoon boat. The Mariner needed the main harness connecter reset about every other trip out but that is about all the maintenance I did to either of them. Both turned into yard ornaments so I sold them not long after I bought them. Just got too busy to use them.
jlh3rd
It's the weight of the heavier gear case coupled with doing this by myself knowing that if I mishandle/slip/drop the gearcase with the prop on it that prop could injure me somehow. It was easier using the prop shaft as a hold point for the 115hp.....the 60 hp was easier to manhandle.
yep, anything to hold the gearcase is fine.
+1 on using a silicon (or non petroleum) grease. I used a non-petroleum grease but thought of silicon spray also and reasoned why not, so the pump housing,impeller got sprayed .
I did lightly coat the entire drive shaft/shifter shafts with my marine grease.....I read not to cover the top of the drive shaft with grease.......so I didn't.
Jeff J
I have a wooden bench that I added 2 spacers and a 2x4 to create a gap to hold the skeg for working on the lower unit. I also welded up an adjustable u-stand I mounted to the end of a work bench. I have simply set the lower unit on the back of my pickup. The skeg will slide in between the tailgate and the bed. Instant lower unit stand if I am not at my shop. Now that I think about it, I have also used my table saw as a lower unit stand. Lots of ways to hold one while replacing the impeller.
Gee, to rebuild the waterpump, I use four cement blocks with a wood pad, or I chuck it in my vise. Easy stuff, as the carrying is the hard part.
