Merc 250 Verado Fuel increase
alldodge
Guessing this is LED's on the throttle handles, and if so I have not watched for them during start sequence
The isolator (might also be a combiner) and and fuse I found
Wiring diagram
So looks like it's a combiner and haven't found anything to change House yet, but may be behind the Boat switch panel
muc
"Retired" Association of Marine Technicians...
The Dual‑Engine Battery Architecture Diagram I posted comes from the
VERADO V8/SEAPRO V8 INSTALLATION MANUAL p/n 90-8M0156798
This should have been in your owners packet that came with the boat.
The Start/Stop All Engines I posted comes from the
Electronic Remote Control OPERATION MANUAL GEN 2 p/n 90-8M0180922
This also should have been in your owners packet.
It's possible that you didn't get them ---- I have worked with techs that felt it would "just confuse" boat owners, so They throw them away.
If you don't have them, I'm guessing you can call Merc for a free copy. They maybe even be available online under owners resources.
alldodge
I did find the install 8M0156798, it was in another folder
I can down load the Op manual, but mine starts port first, so the boat I'm thinking was wired wrong
Edit: found paper 8M0175493 Op and Maint
alldodge
Accomplished Gen 2 Control test SB 2025-05R2 and no beeps
Verified the pic in post 62 is a combiner
ALT test SB 2021-21
Unknown if I have isolator's or not, if they are installed they must be behind the Bat switch panel. Knees were getting to me so did measurements at motor, ALT and Bats
Key OFF Eng Off
House 12.5
SB Bat 12.67
PT Bat 12.73
Key On Eng Off
House 12.49
SB Bat 12.56
PT Bat 12.59
Key On Both Eng Run
House 14.29 to 14.30
SB Bat 14.4
PT Bat 14.5
Voltages at ALT or Motor connections the same. Thinking there isn't any isolator's because voltages at ALT are same as Bat
If I turn the keys ON and press start button before VV fully wakes up, I get beeps. Last season I could do the same and no beeps, also if I wait for VV to wake up there are no beeps. Difference between last season and this is the Bats measured slightly higher voltages 12.8
At the combiner the center post measured 13.9 to 14.1, the left post measured 13.2 to 13.5, the right post measured 13.5 to 13.8
alldodge
When starting motors using start/stop the throttle handle LEDs were lit before during and after start, run and shut down
muc
This isn't how the manual describes sequence of start event. If you are talking about the LEDs on the port and stbd start/stop buttons on the aft face of the control?
Are you starting these engines with shore power and batt charger still connected and on?
But I have no hands on with this ayatem.
alldodge
No, talking about the LED's on top the throttle controls
No, shore power is disconnected
I can start or stop both motors by pressing the start/stop button once keys are turned ON. When starting the port starts first than starboard. When stopping they both stop at same time.
I can start/stop either motor individually by using the keys or the buttons behind the throttle in previous pic
muc
Looking at your voltage readings.
When you started testing had you burned off the surface charge on all 3 batts? Please make sure you do this before any testing if there might be a surface charge.
The numbers at the batts look normal and tell us that the house battery is getting charged by at least one engine.
I have not seen the voltages at the engine ever being the same as at the battery, they will always be different. Tenths and hundreds of a volt matter in these measurements. If the meter/leads aren't capable of seeing these low voltages, it's time to do a voltage drop test between the stud on the battery and the stud on the engine. Both + and - cables.
Please note that if you don't follow "best practices" when doing electrical testing ---- you might not pick up on the underlying issue. On the positive side, in this case that means taking battery measurements at the battery stud, not the ring terminal. At the engine this means at the hot stud and alternator output stud doing KOEO and KOER tests. At the starter solenoid stud when testing during a cranking event. On the negative side, at all 4 of the ground studs.
Please note that the tests in 2021-21 are just for alternator testing! I'm pretty sure Merc put this bulletin out just because techs were sending alternators back for warranty when the alternator wasn't the issue. You should also do testing during cranking, voltage drop shows up best when the circuit is under full load. This means you will need a helper or a min/max setting on your DMV.
The voltages at the the combiner don't make sense to me. If it is a combiner the voltages at the right and left studs should be higher then the center due to the diodes. Maybe look behind the area covered by the wires and see what this box is?
muc
Good, never start engines with the charger in operation.
OK, those LEDs are the neutral indicators. The LEDs I was thinking about are on the port/stbd start/stop buttons. What do those LEDs do when you do the all start?
I'm guessing the double beeps you get during cranking are due to the system not being fully awake.
A double rapid horn indicates denial of the attempted action.
You will need G3 to see what exactly is getting denied. What will happen if you continue to run the engines in this state -- I have no idea. But it is probably best to wait for the system to fully wake up before cranking.
The fact that you don't see any faults on the TechMate tells me they are CCM faults. Only G3 read faults form that computer, note that on your boat the CCM is integral to the throttle control.
I don't know why the port starts first. Guessing this might be something that can be set in G3? Would be a good question for your dealer or Merc consumer tech support? 920- 929-5040
alldodge
Charger had been unpluged for 2 days
It's not 2 quick beeps, they are 2 Reg beeps and just happened the one time so far since the software update
Bats are a bit low from when they were new. These things didn't happen when the voltages were a bit higher. I have 3 new bats and charger so going to try and get some help to change them out. This old guy was able to lift out Merc AGM Bats when replacing first time, but these Bats weight 77.8 lbs going to need a little help. Odyssey says Bats should be ok if disconnected from charger for 2 years
It could be maybe it's just the old charger just won't fully charge the Bats. It show the float starts above 13.5 but keeps dropping until it in the high 12's
alldodge
Muc some of this you know I'm just repeating
Called Merc Tech support, Larry said it's no issue if one starts before the other. All motors leave factory as SB and City code and the cables normally causes SB to start first. If Manufacture changed things were Port starts first is no issue.
Note: Chap didn't want to build this boat with Merc's so guess I got what I wanted :censored:
Didn't make it to boat today had meetings and grass cutting, will try tomorrow
muc
I worked for a Chaparral dealer for many years, rigged, delivered and serviced well over a hundred 26' and bigger. This was over 15 years ago so take my observations with that. Things might have changed.
I don't want to disparage Chaparral, they make a very good boat for their price point. BUT -- and this is problem with almost all boats 26' to 35' at this price point. They give them a "Yacht" class certification. But they aren't built like a yacht would be. They are built on an assembly line and the line can't stop, so this means that the boat might have been designed to have battery isolators. But when the boat gets to that station, they don't have any isolators the correct size. So they will install ACRs or VSRs that they do have on hand. Back when I worked on them, Chap outsourced the electric panels and dashes. When you forced them to build this boat with Merc power, this could have changed so many components. This means that wires and cables will be done "on the fly". So some "interesting" things can happen.
The good thing is that they now build this boat with Merc as an option. Maybe you had a hand in this? :love:
Have you gone thru all the stuff that came with the boat? Back then they didn't come with the documentation that a higher price boat would, maybe this has changed? Things like a (I can't remember what Chap called it) build sheet, bill of materials or as built sheet. This will be a long list of every screw, nut bolt, washer and component that was used to build this boat. Also would be nice to have a wiring diagram/schematic. Understand that these might not be completely correct due the "built on a line" but would be a good starting point.
I would recommend that you call Chap and ask for these for your hull VIN and also for one of the first hulls from when they first started building this model with Merc Power. I'm guessing they should be available in a digital file.
It sounds like you are about to replace a pretty expensive battery package and charger. It would be good to check that there isn't a wiring issue that caused the battery issues. I don't know what the difference changing from Yamaha to Merc would make to the wiring, but it's possible there maybe issues due to that. Also when you install a bigger charger, make sure that the existing wiring will support the increased amperage.
You can get thru these issues. Maybe it would help to remember the quote.
"Believe me, my young friend, there is nothing—absolutely nothing—half so much worth doing as simply messing about in boats,"
This helped me and some of the techs I worked with. I still miss getting paid to mess around in boats!
alldodge
Won't give myself credit for having them build the boat with Merc's, only they were not doing it at the time. When originally looking I found a few used ones in Canada with Merc power, but only Canada
I asked for wiring when I first bought the boat and only managed to get a resembled a stick drawing about the battery connection. To get anything I had to ask a few times to get anything. Not like Formula they give you everything and will give it to you again if asked
Yes I have about 2K worth of Bats and charger and going to replace them in the next few days, have some help lined up. When I get the Bats out this can provide more access to look behind where they sit before installing the newer ones. This Bats are plenty good for some of my other equipment
alldodge
New Bats and charger and all prior issues seam to not be an issue currently, will need to take out a few more tries to verify.
Started charging 3 older Bats with standard charger about 45 minutes at a time and let set for a day. After a few days all Bats appear to be holding around 12.95 or so. RRight now appears to be just be a bad charger
Will see if it holds with more use
alldodge
Probably means nothing but listing just in case
Left the dock with same 2 beeps when placed in gear but found I had no power steering. Left a ground wire off one of the Bats. Pulled back in fixed
Today's run
Again fully powered up and when placed in Rev I get 2 beeps. Smartcraft shows 13.1V (+/-) but does not go below 13V. After reving I see 14.1 to 14.3V on smartcraft. Ran back thru SB test and no beeps
Run for a cruise, sit for an hour, fully power up and place in Forward and get 2 beeps. Will get 2 beeps if I don't let it fully power up and start motors. Motors start without issues but get beeps and didn't use to happen for first 2 seasons
Had Techmate connected and did not see any codes from either motor. with no mater which motor was being watched and heard beeps
On the good side
With Techmate connected and watching Demand, Demand Linier, and others got between 5700 and 5800 RPM and reached 61 mph with demand from either motor not going below 100%
