04 Yamaha 225 4-stroke- -injector harness 2 End Plugs?
frustratedboater
I had pulled my 04 Yamaha L225TURC powerhead to replace an oil pump. Upon reassembly all is connected except the end of the port injector harness, which has two plugs at the end. I am stumped as to where they connect to and can't see any options. I doubt they plug into one another, but look like they would run up to the trim solenoid area. I had taken pics and labeled a few plugs to match up, but this one I did not. I've attached a pic of a harness showing these two plugs going out to the left of pictured, at the end. This is easy stuff, but I'm a little baffled..
frustratedboater
Well boscoe, since I'm not a certified mechanic and have no need to spend 800+ on a mechanics' manual. All I have to work with is the SELOC for my year, so not sure what the purpose of these forums are if this is the response I always get. SO, I guess I'm screwed? ..is that correct?
If you look at my post amts, I've been around for quite a while and seem to get this reaction a lot.
Help me understand the purpose of these forums! Please, so I can approach my questions appropriately.
dingbat
Sounds like you have a need for one at the moment……Factory service manual…$35
boscoe99
Purpose of the forums, in my opinion, is to help people. Teach them.
How to fish. Not to give them fishes.
