BRP outboard old but funny
Yeah, BRP outboards have a bit of a reputation like that 😅. The old Evinrude/Johnson (OMC) designs that BRP inherited were solid workhorses — simple carbs, strong blocks, and plenty of torque. They could take a beating and still fire up, which is why a lot of us still run them today.
What’s “funny” is how quirky they can be compared to modern four-strokes or even BRP’s own later E-TEC models:
  • They sometimes smoke like a chimney when you first start them.
  • The choke/primer tricks can be hit or miss.
  • They’ve got that unique old-school sound — more of a growl than the purr of newer engines.
  • And don’t forget the fuel thirst… those older 2-strokes will let you know where your wallet went!
But when tuned right, they’re reliable, punchy, and keep on trucking long after you’d expect. That mix of ruggedness and quirkiness is what makes them “old but funny” — and why you still see them on the water today.
Do you have a picture of the one you’re talking about? Would be cool to see which model/year you’ve got.
TN-25
You know, it's funny thing that my 1950 Johnson 5-horse TN-26, for all its antiquity (T-series goes back to 1937) purrs like a little kitten. It's smooth, and doesn't seem out-rivalled despite all the later motors with their intake mufflers, rubber donuts and features. The old TN keeps running with minor maintenance, though being a bronze bushed rotary valve motor means when clearances are exceeded, the block & crank are toast. 75 years and counting ain't half bad for just one overhaul.
Crosbyman
nothing beats simplicity... jw cd ad qd fds all great technology that can always get you back like a 2 prop plane "
jimmbo
The OP omitted to mention that BRP also got OMCs Problem Child, the FICHT. They tweaked it a bit and renamed it 'E-TEC.
