looking for recommendations for gimbal bearing puller
2004 searay
i am looking to buy a new puller and the one i have has been very good to me for the past 8 years but i have no idea what make it is and the they all look alike now a days.
anyone have one of the marine tech tools?
how about a puller you swear by?
I just use a slide hammer.
Ayuh,..... Ditto,.... 'n a rear wheel bearing puller end, from OTC, which allows to slip it in behind the bearing, 'n then flips to lock the bearing to the slide-hammer shaft,....
Scott06
Usually use a slide hammer, last one I did broke the fingers of my large slide hammer. Ended up using the axle bearing puller with a fine thread 5/8" threaded rod and C channel to make a puller for more force than the 5 lb slide
