I/O (Sterndrive) Conversion to Outboards
tpenfield
Ribs, gussets, and bolts. . . .:unsure:
While away, I did some detailed drawings of the extension pod and support structure. Yellow is the boat's structure and gray is the extension pod and support structure.
I am going to add a bunch of gussets to support many of the flange areas where the bolts will go. Some ribs to stiffen the long horizontal runs, . . . and lots of bolts, distributing the load.
In total there will be 74 gussets, 16 ribs, and 78 bolts. Since there are so many bolts planned, I am thinking 3/8" fine thread hardware (316 SS). :cool:
alldodge
Assuming flat washers and lock nuts?
Why fine thread, isn't it easier to over torque a bolt using fine?
redneck joe
And being a simpleton wood guy, more nails isn't better. 78 seems alot, but im not any kinda smart guy.
tpenfield
Fender washers and regular washers with nylock nuts.
I figure fine thread is better for both tightening and not loosening
Pmt133
I thought fine was more subject to loosening than coarse... but it's been a long time time since I did materials. Beyond that in the scope of pedestrian hardware I don't know there is much a difference between coarse and fine otherwise. I prefer fine as they nuts seem to thread on easier. No other reason lol.
tphoyt
I’ve always felt like there is more surface area being covered with fine threads and they are less likely to vibrate lose. Just my thoughts.
tpenfield
Transom assembly is fine thread, outdrive to bell housing is fine thread.
Must be a reason.
tpenfield
According to AI . . .
"Coarse thread is more subject to loosening under vibration, while fine thread is less likely to loosen. This is because fine threads have a smaller helix angle, which makes them more resistant to self-loosening from vibration compared to the steeper angle of coarse threads."
tpenfield
One thing about working with SS bolts is 'galling' , which can ruin your day.
I had the issue with my extended swim platform build, so I'll have to be extra careful about the extension pod, considering the number of bolts.
Ted, look for 316-condition B hardware
It's a much harder 316 variant that is less likely to gall
tphoyt
I will have to look into that as well.
I use a lot of stainless for the marine environment on a seasonal basis and even though I know one more turn will be to much I usually do it and then I’m done and have to resort to cutting the bolts when the day comes.
flashback
I suspect once installed the bolts will never be removed similar to the hylocks used in aircraft of old. The head of the nut broke off at a predetermined torque..
dingbat
tpenfield
The 2 tables (5&6) list under water properties.
Keep in mind that the bolts do not (should not) get wet, other than some periodic dampness.
harringtondav
I retired working in heavy equipment transmission/drive train manufacture.
Coarse threads in both cast iron and steel were the norm. I mostly set up the tooling and processes, so I didn't much care why. I assumed with the joint fasteners we used and the required torque, coarse threads provided the require clamping forces w/o loosening. Bolt stretch was key. High grade cap screws in tapped holes mostly. Nuts rarely. Thread locking compounds never.
....I reckon avoiding cross threading in production assembly was a plus.
tpenfield
I brought the extension pod frame outside for a test fit on the boat and to outline the cut-outs.
The fit will need a bit of tweaking, but not terribly so.
I got the matching cut-out areas marked. I'll probably be taking the sawz-all to it this week.
The sides are a bit tight to the trim tabs, so I'll be making some adjustments on the sides.
redneck joe
Thank God now I know what im looking at.....
Why the diff colored things on top?
Why the holes into the bottom of the swim platform? Wire could go thu sterndrive holes?
Tabs should be functionally fine where they are at or what is a k tab?
