maineiac5586
Master Chief Petty Officer
- Feb 14, 2009
- 817
Picked up a nice motor 1996 evinrude short shaft model number e25teeda. I noticed it didn't pee right away. Wouldn't see a stream until 20 seconds or so after starting. I've run a bunch of these and always had them pee right away. I dropped the lower unit down and inspected the pump. The impeller had deformed tips as if they were melted from previous owner running dry. Fair amount of rubber smeared in the impeller cup as well. I shot compressed air up the copper water tube and felt a nice flow of air from the telltale. When I did this a lot of water emptied from somewhere up above like it was trapped or something. This was a good 5 hours after running it. I bought a cheap pump kit(complete with housing) from Amazon in attempt to fix this quickly. Upon restarting the motor after pump install i have no water coming from telltale even after running above idle speed for half a minute or so. I witnessed exhaust like flow coming from the telltale no water. I know I should get an oem pump kit in there but the similarity of the symptoms has me concerned it might be something else. Open to suggestions. Thanks in advance for your time
