Re: How does Speedometrer Work?
Quality speedometers are a version of the "Pitot Static" system. They measure direct water pressure (hold your hand in the water as you increase speed) which is a function of velocity. That's the "Pitot" side.<br /><br />By itself, this measurement is meaningless without a reference, so the "Static" side is a small port open to non pressurized water or ambient presssure. This pressure is the same no matter what your speed and provides the reference from which your dial is calibrated.<br /><br />Your speedometer is actually indicating the difference between the Pitot and the Static presssures.<br /><br />It's not just a dumb guage ... it's actually pretty smart, but both ports need to be clear for it to function properly.<br /><br />There are cheaper models that only measure velocity induced pressure (Pitot). These must be calibrated against a known good speedo, but (in most cases) will be innacurate at the ends of the scale. If you set it to 20 Kts against a known reference, it will be progressively in error the further from 20 kts you get .. either slower or faster... But a couple knots either way won't be important to the average user.
