Re: Briggs and Stratton outboard
Sloopy, good morning. I meant same type of fuel, not same tank. When on fishing vacations, I carry extra cans of gas in the boat that I can pour into the built-in tank if needed. This is the fuel I would use, pre mixed with 2 cycle oil. This way I wouldn't have to carry along another can with plain gasoline.<br /><br />Anyway, if I have a fuel problem that causes an engine failure, I'm up a long river with a very useless paddle. The nearest gas station is 50+ miles away on a rough logging company owned "road".<br /><br />Glad you had no problems with your water mower. I will have to think on this for a while. Dad still gets a healthy discount on B&S products, but I don't know if or when it would apply to this motor.<br /><br />I suspect the trolling warning is a cover your axx approach by B&S, and that except for use under extreme conditions, everything will be ok.<br /><br />I've got a question for you since I still have not been able to see one of these in person. How is the throttle set up? Traditional twist grip in the handle with spring return? Or sliding lever on the front of cowling?
