Hi, I have a '92 Suzuki DT25 and am trying to find out the best way to adjust the pilot screws to the best posn. My service manual tells me they should be 1 to 1.5 turns out (from seated posn) but how do I optimise them. <br /><br />On single carb engine I just turned screw at idle and set it at mid point between where the engine started to bog down (well actually slightly richer than mid-point). What is recommended procedure to do this with 3 carbs. <br /><br />Engine does not idle atall well (although it runs fine at higher RPM). <br /><br />(I've still to check reverse switch / resistor and throttle sensor which can both also apparently affect idle but want to adjust carbs anyway)<br /><br />Thanks.
