Steering cables
Barnacle_Bill
I have an old dual cable (Teleflex) steering system. The outer sheath appears to be in good condition but the steering has gotten stiff over the years. (its not the motor). If I take it loose from the motor, can the inner cables be removed and lubed? I did take them loose at the helm and lubed what I could and that helped a little.
rickdb1boat
Re: Steering cables
Something like this may work: Looks like it only good for the tube, though.....<br /><br /> web page
Barnacle_Bill
Re: Steering cables
Thanks, but that part is OK. I think the problem is the lube inside the sheathing has gotten hard over the years.
ebsworj
Re: Steering cables
Don't waste your time lubing. you need new cables
Re: Steering cables
Ayuh,........<br /><br />The Cable is a Non-Servicable Part........<br /><br />Replace it......
