1998 Yamaha 150 Trim motor oil?
Badger999
I see a little resivior with a screw off cap next to the trim motor. Assume that gets hydraulic fluid. Can dot 3 brake fluid be used or does it have to be something special?<br /><br />Thanks
Badger999
Re: 1998 Yamaha 150 Trim motor oil?
Someone must know the answer to this?
bigbrownbuku
Master Chief Petty Officer
use auto trans fluid not brake fluid. the cap is also the fill line with the motor tilted all the way up and supported while you are under there.
