Yamaha 115 wont stop
bevans
I am still having problem with a Yamaha Autolube V4 115 ("BETO" on lable?) which wont stop when the ignition is turned off or when stop switch activated on the 703 remote control box. The white return wire in the engine junction/control box is going to deck (neg.) so wiring loom ok? What Is the engine junction box and is there a wiring diagram available.
rodbolt
Re: Yamaha 115 wont stop
remove the cover for the CDI. start the engine. use a jumper from a good engine ground to the white wire on the CDI. if it dies, trouble shoot the stop circuit.<br /> good luck and keep posting
bevans
Many thanks for clues. Found intermittant high resistance connection on plug on engine cable loom. This would read low ohms on test meter but take no current.
