Hello I have a 2000 Yamaha 250hp EFI V76 SWS II motor with 230 hrs and an intermitant problem. <br /> Goes like this-Start up motor let idle for 10 to 15 minutes, go to give throttle and at about 35 to 37 rpm's just before the boat will level off to plane it just shuts down and runs very rough and will not take throttle. If I pull back on the throttle it will calm down and then when I go back to the gas it shuts down again. If upon shutting down I leave the throttle advanced the motor will run very rough and die completely after a minute or so. The problem is it doesn't do this all the time. Sometimes it will start and take throttle and run beautiful. <br /> If the motor doesn't die the first time upon giving it throttle it will run great. <br /> I brought it to a yamaha dealer and first he said the VST filter was clogged and he cleaned it. No change in the way it ran. He also did compression (100 ea)and checked the rest of the fuel system found nothing wrong. Any suggestions??
