Summer Breeze
Thread starter- Joined
- Jul 25, 2004
- 25
Suddenly my motor (1999 F100) has started to run pretty ragged. Hard to fire up and maintain idle and seems to only be firing on two cylinders. Did some basic trouble shooting with my brother in law who is an auto mechanic and here is what we come up with:<br />Cylinders 1 and 4 not firing properly<br />All spark plugs burning clean; none fouled<br />All plug wires generating spark<br />Swapped the coils and removed individual plug wires with motor idling to see if one of the coils could be bad - negative<br />Doesn't seem like a fuel filter problem because motor will run at almost full power at higher RPM's 3000 to 5000<br />Checked the fuses they are OK<br /><br />The motor seems to have been running fine over the last couple years with the exception of occasional blue smoke on startup.<br />I am planning to have it serviced soon, but most places down here are booked for the next couple weeks. I'm wondering if you guys may be able to shed some insight into this , seen similar occurrences or can give me some idea of what to expect in terms of repair.<br />Thank you.<br />
