'94 150 proV problem
basschaser
I have a 150 proV and right off the trailer it runs like a top, but seems like when the motor warms up, approx 10 minutes run time it looses power. Off the trailer it will turn up around 5100 rpm but after the power loss it will only turn up around 1400. Just rebuilt carbs and I'm wondering if I have something electrical breaking down as the motor temp rises. Any ideas where to go from here?
Ray Neudecker
Re: '94 150 proV problem
Time to do a compression test. If compression is good, then you need to check the fuel delivery system. Those models were also common for fuel pump problems, but the symptoms are rarely that severe.
basschaser
Thanks for the help Ray, compression check turned out good, went on to fuel delivery and found I had a fuel line collapsing between the tank and the bulb. replaced fuel line and she runs like a top. Thank you again. Got her fixed on Friday and finished 2nd in a bass tourny on Sat.
Ray Neudecker
Nice job on the trouble shooting and fishing. Happy Boating.
