Suzuki DT115 High speed problems
Status
Not open for further replies.
jimowen
This saga will be long and verbose, but The entire story will let you see what I've done (to no avail).<br /><br />I just bought the boat (20ft Bayliner Trophy '81) with a Suzuki DT115TCLS (9/23/94 mfg, '95 model). The guy I bought it from had been tinkering with it, and couldn't get it started.<br /><br />It had been "running fine", and then got rough, then died. He spent several days trying to get it running and gave up ($6500 as-is).<br /><br />When I started working on it, I checked every coil, every sensor, every connection. Eventually, I found the Flywheel key sheared (about 60 degrees out of time) I replaced the key, and it started right up. It now idles fine, runs smooth, compression is ~115 each cyl., but will only top end (under load) at about 2800-3000 rpm. In neutral, will hit 6K easily. In neutral, it appears to accelerate normally, and at about 2800 rpm, there is a definite change in the sound of the engine (spark advancing?) and it then accelerates rapidly. (None of this happens, when in gear)<br />All sensor readings appear normal, except the throttle position sensor (which was recently replaced). My measurements show only .1 to .25 volts (should be .45 to .55 v at FCT)<br /><br />Even though Suzuki says "CDIs never go bad", I have swapped several "good" CDI units (albeit from older model engines) to see if it was the CDI (No change in performance)<br /><br />My questions are:<br />1. Does this sound like a purely Throttle sensor problem? (any "tweaks" to verify?)<br />2. Since the voltages being supplied are from the CDI (and they are low) does this tend to mark the CDI as bad? ($1000+ to replace new)<br />3. Are there any specific voltage/resistance checks that will positively confirm the CDI is bad?<br />4. Since the engine spins up to 6K with no load, does that rule out gummy carbs?<br />5. Is there any other relatively simple thing that may be causing a loaded top end of only 3K?<br />6. Are there any remote connections that could be shorted/corroded/open that could have this effect?<br /><br />V1700 prop is installed (same one as always) that previously got 5200-5500rpm.<br /><br />Thanks for any help, I'm stumped without more detailed schematics of the "black box".<br /><br />Jim :confused:
D
DJ
Guest
Re: Suzuki DT115 High speed problems
Jim,<br /><br />You can just about bet it's gummy carbs.<br /><br />Any outboard will rev up to it's full potential while running with no load. And they will sound OK too. A four cylinder will easily rev up running on only two-with no load.<br /><br />I owned a DT-140 of the same year. It's the same engine.<br /><br />I had to clean the carbs. (4-Mikuni's) annually. :mad: <br /><br />It would act just like yours is.
TexSkeeter150
I agree with djohns19. I just sprayed Beremans(sp?) B-12 in the carb at idle and ran two tanks with B-12 in the tank. Had immediate results and runs like a champ now. I would recommend that you change out the fuel filter after doing this also. Good luck
jimowen
Nope! That didn't fix it. I did succeed in fouling out 3 of the four plugs before I got that one figured out though... The carb cleaner makes lots (breaks loose?) lots of carbon, and those brand new plugs had resistances of about 10K (instead of infinity). Ran 5 gals of new gas with B12, still only turns 3K (under load). I have the throttle position switch ordered, but I still don't believe that will fix it. I also noticed the charging circuit didn't come up to power until the engine was over 3500... that seems a bit fast to first charge the batteries (with battery only at 12.4) does about 12.5 at idle, 12.7 at 2300, and about 13.5 at 3000)<br /><br />The previous owner said he replaced "one of the coils under the flywheel". I've checked the resistances on all of them and they are within spec. Could there be a different "high power" coil required in a newer engine? (Still just guessing...and trying to avoid buying the CDI)<br /><br />Thanks for your help up til now... the carbs are clean, the fuel filters are replaced, the spark plugs are replaced (again). Compression is now 125 in all cyls. I did notice a rough spot on acceleration - at about 2600-2800 (no load) which I assumed was where spark advance kicked in.<br /><br />Another question - since the fuel pump was recently replaced, I presume it is good. Short of sticking an in-line gauge in the fuel line, is there any way to be sure it is providing enough pressure? I think that at high rpm, the same amount of fuel flows whether under load or not (bournoulli's principle?), but am not sure.<br /><br />regards,<br />Jim
jimowen
FIXED IT!!!! Now that I've rebuilt the carbs, cleaned everything, wiggled everything and it still didn't work... I returned to basics (for the third time)<br /><br />The local tech said to disconnect all the sensors, if that fixed it, that sensor was at fault. Well, I knew the throttle position switch was bad (incorrect voltages), but removing it didn't fix the problem. So, this time I got creative and SHORTED the two wires...Voila! Ran like a scalded ape! Took it out for a quick spin and was registering 46 mph (gps). Thanks for everybody's help! (New part is ordered)
errol_white
Scalded ape. Good one! Maybe once I get my motor above 3200 RPM...
Suzuki Nut
Hi Jim, I know I'm a little late replying to your problem but I have a similar situation with my 1989 DT115, lost full throttle rpm and acceleration out of the hole ! You seem to have found the problem with your engine by shorting the two wires on the TPS ? Can you tell me exactly what you did and how you shorted the wires ? Maybe we can talk about it some time if you can contact me thru the AOMCI ?
MOD EDIT: Yes, 20 years late. Please review the forum rules regarding posting to old dormant threads. It is best to start your own thread with the specific information.
Status
