FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
2002 225 efi 2 stroke<br />Temp on gague reads 200 deg. Doesn't seem right. The stream from the tell-tale is only warm to the touch. Should the tell-tale stream reflect the temp gague?<br /> Thanks, Dead Eye
The temp gague reads the metal on the head. From what i can see there is a sensor on the top of the head. I ask these questions because my old motor 1988 150 tha tall-tale temp seemed to represent the head temp. As the motor heated up the tell-tale stream was HOT.<br /> Thanks, Dead Eye
The water in the tell-tale stream passes through the power-head before exiting the tell-tale. Am I right? If so as the temp on the head rises the temp of the stream should increase. I am not saying the temps should be equal in degrees. I would think if the head temp is around 200 deg the telltale stream should be very warm if not hot.<br /> Thanks, Dead Eye
You need a book. The water flow on these vary. My opti pisser gets water from midsection, up thru the fuel rail and into air comp, and the to the pisser. Never goes thru the motor.
