What you call the stream of water coming out of the motor....
Mark42
A) Pisser<br />B) Wizzer<br />C) Tell Tail<br />D) Telltail<br />E) Telltale<br />F) Pee hole<br /><br /><br />The correct answer is....
LubeDude
Re: What you call the stream of water coming out of the motor....
Its all good as long as its there???????????
JB
E<br /><br />Do I get a prize??
jtexas
What do I call it? telltale.<br /><br />I think the clinical term is:<br />Overboard Water Indicator.
Reel Poor
ooooohohohohoh I know ohohoh....Its E
alden135
I thought that was a fuel overflow fitting. I plumbed mine to the gas tank.
Reel Poor
Originally posted by alden:<br /> I thought that was a fuel overflow fitting. I plumbed mine to the gas tank.
aaawwwweee alden. Look on the bright side.....Your tank will never go empty.
Mark42
Yep, it's E. I think I've even typed it as tell tail. But I got to thinking about it and looked it up, and sure enough, it is Telltale, as in: "The boat left a telltale oil slick on the water where it sank because the owner put poly resin over epoxy and the transom fell off".<br /><br /> :D
KRS
Banned
My 120 mercruiser alpha one doesn't have a stream of water coming out of the engine... if it did I'd take it to a repair shop :)
eli_lilly
I did notice that my 72/73 Merc factory service manual calls it a "tell tale".
sumcat1
How 'bout virtual water pressure guage
D
DJ
Guest
E.
Ron G
E,or hurt neck for always turning around and looking :)
Mark42
I can't see the telltale from behind the wheel in my boat. Was thinking of putting a piece of copper tube bent like a U so the stream would shoot up and back. Kind of Jet Ski style so I can see it while I'm running. But, it could be a problem when at the docks with a water stream shooting 6 to 10 feet behind me. :D <br /><br />Have a few more gadgets to add to the boat, a water pressure guage will probably be one of them.
steelespike
I call it wet.
Mischief Managed
In New England, we call it the "wicked pissah".
alden135
Originally posted by Mischief Managed:<br /> In New England, we call it the "wicked pissah".
DISCLAIMER:<br />Views expressed by Mischief Managed are not necessarily representative of the rest of NH. :p
eeboater
I call it A.
tommays
NO NO a telltale is on a sail :confused: it must be something else :D <br /><br />tommays
