FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Are you getting anything at all? A click? Try going directly to the starter with jumpers and see if it turns over. The engine will turn by hand, right?
what it going? won't turn over isn't very descriptive. is it clicking, is starter spinning & not engaging in flywheel? need more info to start to make a guess. have you tried taking the plugs out and turning by hand? by the way, welcome to iboats.
When i turn the key i get a short click. I checked the voltage at the starter and i am getting 12.45 volts. I also can't get it to turn over by hand pulling. The engine does turn by hand, and i will try to take jumpers to the starter. Thanks Tiller71 , I will try some WD40.
If the motor will not turn by hand do not try to jump it. Pull the plugs and put a few squirts of marvem mystery oil in each cylinder and spary air in there to swoosh it around (with the motor in the travel position). Give it a day and then try to free it up. Beings that I know alittle personally about this engine I am rather sure it is nothing major. Just sounds like you have some corrosion and it will take a little to free it up. If that fails bring it over to 34's Saturday and we can free it up and run it in the dunk tank.
