NEED MECHANIC INPUT
bowlin257
Got the gasket today to seal the water jacket area over the cylinders, the plate the spark plugs go thru. I ask about using a gasket sealer or dope and the Mercury mechanic said not to use any except a dab of grese if needed to hold the gasket. He said not to use gasket dope on any gasket on a Mercury. If any gasket needed a sealer I would think this gasket would. Is he right? I'm inclinded to smother it in Permatex, non-harding dope to get the seal around the plugs.
T_I_M
Re: NEED MECHANIC INPUT
I would use a gasket sealing compound but the Permatex will work to. Just don't go nuts.A very thin layer is all you need and won't hurt, especially if the surface is a little rough.
Clams Canino
Don't smother it... a thin layer is fine. I use Permatex black silicone type on those covers.<br /><br />-W
WillyBWright
It's rare to get the old one off without damaging the mating surfaces. In general, gasket sealer is only used when the surfaces are damaged or if you're re-using an otherwise good gasket. The grease idea is a Real Bad one. It prevents the gasket from bonding to the metal. And if pressure got too great, the grease would provide lubrication for the gasket to bulge out.
