FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
tom,<br /><br />We need more info,and then maybe we can help.<br /><br />Will the motor start.<br /><br />Will the motor crank over when you pull the recoil.<br /><br />If the motor is not running have you turned the propshaft when trying to shift.<br /><br />Also how full is the gear oil,and what does the oil look like.<br /><br />Just a start,trying to help you.<br /><br />DHP
After the motor quit I could not get it started again, It will turn over, I tried turning the prop shaft and shifting but it still would not shift, the oil was in good condition
remove 3 screws at base of tiller handle and remove cover plate this is where cables are connected they could be broken there or just come of, caution take note where cables go as can be a bit tricky to get back together
thanks for the help, after looking the cables over, i took the bolt out of the shift gear on the motor, it was not in the cog of the shifting gear, reinstalled the cabled gear and it shifts ok now. thanks again, tom
