roger3645
Thread starter- Joined
- Aug 30, 2005
- 271
Im running a 1975 850 85 hp mercury serial #4300733. Yes and Im very glad that it still runs as well as it does. The only problem Im having is it will just cut off. This occurs at WOT. It will run for a while at WOT then just shut off. Just like flipping a light switch. It will start right back up. Im wondering if Im exceeding maximum rpms. Dont have a tach. Running 2 bladed 19p prop on a 16ft tri hull bass boat. The boat will top out at 33 mph. Did try a 21p prop which over propped the boat (max of 21mph) Do these motors have an rpm inhibitor to shut down the motor if max rpm is exceeded?
