Re: 1999 mercury 90 hp no fire
lows and highs are not peak voltage, ya cannot get a peak reading with a standard voltmeter unless it has a DVA setting or adapter. by the fact your getting anything leads me to belive your stator does not have an open winding, while your metering shift to the Ohms scale and have a look at the resistance, also check each stator lead to ground,<br /> but without the DVA or a CD-77 type meter any readings you get are flawed and cannot really be used as a test.<br /> the CDM's will actually produce spark all the way down to about 65Vpeak.<br /> the stator is producing ac voltage, however we are usining it to charge capacitors not power a fan, thats why we need peak voltage and not RMS or average.<br /> you can get a rough estimate by multipling the average voltage that most meters use by 1.414 and get a reasonably close measurement of peak for this purpose.<br /> if your stator was open circuited, normal failure, your meter would read nothing out, if one leg was shorted to ground you may see the signal but the ecm would not see the correct signal. thats why a short to ground test is essential on a two wire non grounded coil.
