cheburashka
Thread starter- Joined
- May 28, 2005
- 715
I've been looking for a control box for a '69 500, serial #2626372. I've found a complete unit with single lever (no warmup lever) which was intended for a Mark 50-something. It's white, and shaped pretty much like an old Swing-A-Way can opener, if that helps. The plug is identical to the socket on the side of my motor. The only difference I can see is the lack of the extra lever for warming up.<br /><br />I've found it very hard to locate any control boxes with the plug still attached. Were there major internal changes to the motors between the "Mark" series and the later Thunderbolt ignition models? My major concern would be whether the ignition switch is one that grounds out the coils in the off position (early magneto) or applies power to the coils in the on position. Anyone know whether the basic electrical connections remained the same?<br /><br />Thanks for the help.
