My neutral lock on a Quiksilver3000 does not work. has anyone tore one of these apart for teh same problem. i have taken the back off and doused with wd-40 to no avail. the button will push but will not activate shifting override. help me please
Originally posted by TUCKER1:<br /> Push the throttle only button in and push the throttle forward. Now pull out the throttle only button and remove it. It pops out.You might need a sall flat head screwdriver to get it started <br /><br />This will reveal a hex head bolt, remove it and the handle should pull off. Them separate the handle in half. That bolt should get some Loctite when you put it back in.
