surphrat420
- Sep 30, 2003
- 30
Sorry for the long and bewildering post...Ive posted some on this subject before.. but i have some new updates. I was getting water in my lower unit on my 1980's 200hp black max. After changing water pump kit, shift shaft seal kit and prop shaft seals (both seals, not large o-ring, could not remove bearing carrier). So after all this it passed a 15 psi pressure test under water and out. So off to the lake, upon returing i checked the gear lube and it bubbled and fizzed when i stuck a hot metal rod into it (not to mention it was no longer clear, like the lube that went in) So i guess i still have a leak. My next step is where I discovered after changing the lube and running it OUT of the water but on the hose, that water was STILL getting in! So it has to be the water pump, right? I inspected it today and it was new a month ago and still looked good today, ( I made sure to reassemble it according to the exploed diagram on the mercury parts page.) and after all that STILL LEAKING! the drive shaft has a TINY ream cut out just around where the water pump, oil and water seals would sit. Would this casue a leak enough to emulsify my oil after 10 min on the hose?
