Vintage 115 tilt/trim - won't lift without help
Alan June
Hello,<br />I just brought home a boat won on ebay with a 115 Mercury. The boat is a 79. Motor looks to be simular vintage. <br /><br />I read all the tilt/trim posts I could find on the site, but could not find one with the same issue.<br /><br />When I picked up the boat the motor was locked in the trailer position. When I went to launch for the first time I unlocked it and the motor went down slowly by itself.<br /><br />The trim pump runs in the up position but will not lift motor unless I have someone lift the motor the first couple inches. Then it will lift the motor all the way up.<br /><br />It will stay for a few seconds then slowly go down.<br /><br />It will power down as I think it should.<br /><br />I checked the oil level and it was full.<br /><br />Then I removed the vent screw and ran it up and down a few times with lifting by hand for the first few inches being required each time. Thought this would bleed the air. Still same problem.<br /><br />Any Thoughts?
Laddies
Banned
Re: Vintage 115 tilt/trim - won't lift without help
Is the manual release turned all the way out, if not it won't work properly
Alan June
Laddies, I checked the manual release and tried again. Still same problem. Thanks, Alan
timmathis
Pump will probably need to be rebuilt. If you cant find any leak / air in the system.
jheron
I would say the cylinders need rebuilding and not the pump(When the pump wares out throw it out, there aer no serviceable parts) The cylinders are easy to do ... do a search and you will find where I describe the slipper seal re-assembly without the need for the merc tool. or post back and I can tell ya how to do it ;) <br />Jon
Alan June
Thanks for the help all. It turned out to be the cylinders. Good call jheron
