Rock Hall
Thread starter- Joined
- Sep 6, 2005
- 213
This is my first post to this board. Thought I could handle the problem myself, but I need help. Here's the story:<br /><br />I have a 25HP 1986? MARINER. This motor has been flawless up until a few weeks ago. I was running at about 2400 RPM (guess)and all of the sudden it was like I hit something motor just shut off. I didnt hit anything I,m sure. The motor would not restart. Tried to start, was like the kill switch was on. Then tried it again 45 min later as the tow boat was heading out and it started. Ran for about 30 sec and shut off again. I kept trying to start it over the next few days and nothing. I took it home to dig in and try to figure out what was wrong. <br /><br />Using a spark tester, I determined that there was no spark at either cylinder. After running this by a few mechanics, I was told that it was most likely the switch box. The only way to test was to bring the boat in and have them test it with everything assembled. 2 week wait. I opted out of that idea.<br /><br />After getting gouged on a new switchbox, I installed it and nothing changed. My next thing to try was the stator. My ohm-meter showed a dead short on the low speed coil. So I ordered a new stator installed it and WALAH, first pull it started. It didnt seem to be running 100%, but I thought I'd wait till I got it in the water and see how it runs. Put it in the water over the weekend. Started first pull, seemed to run ok, except it was breaking up pretty bad it high speed. I fooled around with the timing linkage and it seemed to get better. Ran about 90% good. Ran it around for about an hour. Next day, put it in the water and it seemed to run ok, not great but ok. Pulled it out of the water, put it on the trailer and took it 5 miles down the road to another ramp. Loaded it up with a few guests, pulled the starter and nothing. would not start after an hour of pulling totally dead. an occasional fire, but no start. after putting new plugs in and rigging the starter so that I could give it 3/4 throttle to start, I got it to run on one cylinder.Pulled it out took it apart and determined that there was no low voltage coming from one side of the switch box tested coils wires and plugs by switching them to the other cylinder. So I figured the switchbox fried on one side. No problem since I had another swichbox at home. Brought it home and tonight installed the other switch box. started first pull, but only one cylinder, but ran better on one cylinder. Tested for spark and sure enough, the top cylinder is dead. I did see some spark on one pull, that was it. so I think I'm getting an occasional spark on the top cylinder, but 90% of the time nothing. checked all the grounds and the connections. The only ignition part I didnt replace was the trigger coil. I'm not sure exactly how that works so I dont know if it could cause this problem. <br /><br />Thanks in advance, I hope someone has some suggestions.<br /><br />Mark
