'01 125 mercury lack of power at take off
jaxsun
took my boat out today for the first time only to become disgusted...motor sounds like its bogging down when trying to plane out...its like the secondary carbs are waiting to long to engage...when they do engage the throttle is past the halfway mark and the boat shoots out the water...is there a way to adjust the secondary carbs to engage sooner or does it sound like my problem lies elsewhere?...any comments would be welcome
jaxsun
Re: '01 125 mercury lack of power at take off
just a thought...could the fuel pump be the culprit?...it sounds like its starved for fuel...anyways... :confused:
jaxsun
Originally posted by IBNFSHN:<br /> What does it run at WOT?
mph or rpm?...WOT is awsome...its turning 5000ish wide open...speedo port was plugged so i dont have a mph
jaxsun
:confused: anybody?
andy6374
I'd say you should start thinking about ripping off the carbs and doing a cleaning. Disassemble, soak in carb cleaner, dry and blow out every orfice with compressed air, and reassemble with new gaskets. Easy job, should be able to get them off the engine, clean, and back on the engine in one day.<br /><br />-andy
jaxsun
thanks..i'll do that and rebuild the fuel pump
