Merc 150 Overheating
krobarge
Have an '83 Merc 150 that alarms (overheating?)after 1 minute when I bring rpms up to about 3500 Motor has not been run since last fall, just getting it ready. Peeing great, water is hot but not sure if this is normal. Both sides of block ejecting water. Water pump not old. Used in salt and fresh water. Any suggestions?
dakk1
Re: Merc 150 Overheating
I would suspect the impeller. Just replaced one that was a year old with very few hours on it. It looked like a dog had been chewing on it. It would still pump water at low RPM's though.<br /><br />Dave..
KCLOST
What type of alarm are you hearing?<br /><br />Is it a constant "beeeeeeeeeeeeeeeeeep"? Or an intermittant "beep,beep,beep"?<br /><br />The constant indicates overheating, the intermittant indicates an oil injection problem.<br /><br />Let us know...
dakk1
I didn't think 1983 had oil injection.<br /><br />Dave..
krobarge
The beeping is constant. Engine does not have oil injection. Water pump is 2 seasons old but has less than 20 hours on it.
KCLOST
Yep, your right-no oil injection!<br /><br />That impeller is the first thing you should check as dakk1 mentioned.... Does your engine have a poppet valve...<br /><br />I need your serial# to determine that...
