NYLaguna2100
Thread starter- Joined
- May 21, 2005
- 14
Hello,<br /><br />I am trying to get my Tach to work. I thought it was just a bad tach and purchased a new one and still not working. On the old tach when I would remove the silver send wire and put it back on the tach would bounce a little bit around so that is why I thought it as bad. Someone told me to ensure I am receiving good voltage and the motor is charging normal at around 12 or so volts and rises just a bit when given more throtle. On the back of the tack, I have 2 purple wires going to the Ignition post, 2 ground wires, and a silver wire going to the Send post. I also checked that the tach is getting power. Any suggestions would be greatly appreciated. Is there another wire I can just splice off coming out of the wire harness?? Thanks
