aidenscott
Thread starter- Joined
- Feb 18, 2005
- 10
I just bought a 1999 40 H.P. Mercury and it doesn't run to par. It idles well and if you slowly give it gas, it will get top speed. If you "goose" it from an idle, it will fall on its face and even stall. If you come off from top R.P.M. quickly, it will stall or miss. I changed the fuel and cleaned the carbs. There's a white needle valve on top of the three carbs called an "enricher". This piece has two wires running from it. Could this be the problem? If not, what could it be? It has spark and compression.<br /> Thank you,<br /> Rich
