hooksetter62
Thread starter- Joined
- May 16, 2005
- 40
i have a 1989 mariner mag 40 4 cyl,it seems that the oil injection is smoking much more than normal,smokes very bad and seems to be running rich. is it possibe for me to disconnect the oil tank and just add oil to my fuel tank? as i dont trust the pump system anyway. also what would be the proper ratio of oil to gas? 50-1? i use a 12 gal tank. cold start problem is how can i check the choke solenoid to see if it is priming the carb? i have to crank and crank before it will start, some times it may take 5-10 minutes. dont want to take my starter out. how does the choke solenoid deliver the fuel for cold start? i only have about2-3 hundred hours on this motor and it has always run smooth, like a car. i have had new plugs installed and the lower carb overhauled as it was leaking fuel. all and any help would be appreciated, as the marinas are very very busy and VERY EXPENSIVE. many thanks- ed eckert gladwin michigan
