tompowers85
Thread starter- Joined
- Nov 28, 2004
- 125
I have a problem. I have fuel leaking from my carbs and i have replaced everthing but the fuel tank. I am getting air in the lines some how. If my tank is not holding pressure will that make a difference. I have plugged the vent and prime the bulb and it only stays hard for a minute or two, and when i prime it again my carbs start pooring. I cannot think of what to do. I rebuilt the carbs i have set and adusted everything several times and i cannot get the problem fixed. I have an aluminum 18 gal tank that cam with the boat and it is about 30 years old it does not leak fuel, but if their is a broken weld around the vent or fill tube can that cause a problem.
