Engine Removal---383 stroker
rlelovic
I want to pull my engine this year to build a 383 stroker. I blew a head gasket at WOT which has destroyed the engine (runs but has miniumal power)I do not have a manual. Does someone have the information available? The engine is an 89 350 mag mated to an alpha drive. In addition, I might switch to a bravo unit as the HP will be about 330 which will push the limit of the alpha. Any info on the conversion process will be helpful
JB
Re: Engine Removal---383 stroker
Howdy, trickcraft.<br /><br />Welcome to iboats. :) <br /><br />This is the Mercury OUTBOARD forum.<br /><br />I will move you to the I/O forum.<br /><br />Good luck. :)
