Clams Canino
- Jan 10, 2004
- 2,179
While I'm here:<br /><br />If you have any of the "direct charge" Mercury inlines from the 1500 down to the little 402 40hp model. Remember the following.<br /><br />1. 21 degrees max advance isn't just the law - it's a good idea. If your timing sticker says anything from 23 - 27 degrees, it really means to say 21.<br /><br />2. Change the impeller at LEAST every other season. Every season if you run through a lot of sand.<br /><br />3. Keep the fuel system clean and use at least mid-grade gas.<br /><br />4. Make sure it's propped properly so that it runs near the upper limit of it's rpm range. This does not mean you have to run it there on a daily basis.<br /><br />5. Use a can of Mercury Power Tune AT LEAST once per season. I see more cylinders dead from coked up stuck rings - than any other single cause. <br /><br />-W
