Re: prop selection
The correct size prop is the one that allows the engine to achieve the recommended RPMs at Wide Open Throttle. In the engine handbook it will state Max RPM at WOT. If, at WOT, the RPMs are less than spec, then put a smaller pitch prop on. If they are too high, then a larger prop.<br /><br />Chris.............
