prop ventilating
albass
how does one go about ventilating a prop without destroying it in the process and what advantages will this procedure accomplish. Stainless prop will it help overall performance?
sundog
Re: prop ventilating
what do you mean? ventilation and cavitation commonly refer to air around the prop causing it to overspeed. Ive never heard of an actual prosess on the prop called ventilating...
emckelvy
He's talking about drilling ventilating holes in the propeller, to allow the motor to spin up faster upon takeoff, to get a better hole shot.<br /><br />This is good for water skiing amongst other things. You do have to be careful to drill the holes in the right spot, also you can't go too big or the prop'll slip a WHOLE bunch. I had an old Merc 700 dockbuster with 2-bladed bronze prop. Drilled a couple of ventilation holes in it and it had a takeoff like you wouldn't believe!<br /><br />You can look at some of the hi-perf props to see where they position the holes. This info was available somewhere but I can't seem to place it.<br /><br />If you want to list your E-mail address here in a manner which can be deciphered, but won't be susceptible to spam, I can send you a .gif file which shows exactly where to position the holes. <br /><br />Unless one of the Inline Dudes cares to post a link to the file!!!!<br /><br />To describe roughly, drill holes away from the internal stiffeners of the prop, at about 5/16" +/- 1/16" from the leading edge of the propeller (the most forward edge), where the blade fairs into the propeller body. You probably would want to start with a smallish hole, something like 3/16" or so. I had pretty big holes in the old Merc prop, and at a sloppy 5/16" they were almost too much!<br /><br />If you were to look at the prop from the stbd (right) side of the boat, the hole is ABOVE the front edge of the prop. This allows exhaust gasses to flow over the blades and "ventilate" the prop in a controlled manner.<br /><br />Once up to speed, exhaust is pulled out the rear of the prop, and a minimum amount of exhaust spills out the holes. <br /><br />Note on some hi-perf props they come with plugs so you can choose to ventilate or not.<br /><br />HTH, if you're doing this at home, measure carefully, you're on your own and do so at your own risk!!!!............ed
Barnacle_Bill
You do have a thru the prop exhaust don't you? Otherwise the vents being talked about will not work.
sundog
Well, I learned something today. never heard of it. sounds like a great idea, but the thought of drilling a hole in my prop kinda sends chills...<br /><br />but thanks!
phatmanmike
i have the OMC service report that shows in detail how and where and what size to make those holes... i di it last week, and now i can take off and throw you from your seat with absolutely no diffrence intop or mid speed either<br /><br />email me if you want it.. i would post it here, but it would be illegal...
Hooty
Originally posted by IBNFSHN:<br /> You do have a thru the prop exhaust don't you? Otherwise the vents being talked about will not work.
If it's over-the-hub exhaust, the venting is already taken care of. ;) <br /><br />c/6<br />Hooty
